Autronic ECU 99-00 WRX/STi plugin ecu board
- Snake
- Август 2012 / 593
[size=1em]Autronic is a Australian owned company that is based in Melbourne. The company was formed in 1987.
[font=verdana]Autronic now produces three engine management models, the SMC,SM2 and SM4 plus replacement boards for Subaru WRX and Mitsubishi EVO cars. All offer three dimensional mapping of fuel and ignition and are full sequential. Also two exhaust gas analyzers, the A and B models.[/font]
[font=verdana]All Autronic engine management systems are available with the optional Autotune ™ chip and software which enables hands free tuning with no input is required from the user other than running the engine through its various RPM and load sites.[/font]
[font=verdana]The company is only small but this has not stopped its sales of engine management systems to many parts of the world. The engine management systems are well respected for there reliability and resistance to interference from other engine components.[/font]
[font=verdana]Autronic engine management systems will control injectors correctly, and are renowned for their ability to control large injectors on small capacity engines at small injector openings.[/font]
[font=verdana]Autronic engine management systems are used across the world in race engines in Group A and N touring cars and rally cars, Drag racing, Water ski race boats, Power boats and have won major races world wide.[/font]
[font=verdana]Autronic injected ski race boats won the recent 2001 world ski titles in the USA, taking first and second place.[/font]
[font=verdana]Autronic has produced replacement ECU boards for the original ECU on Mitsubishi EVO 4,5,6,7 and 8. Subaru WRX 1995-96, 1997-98, 1999-00 and 2001-2005. Honda Civc/Integra 1992-95 (OBD1) and also 1996-00 OBD2 cars when used with the supplied adapter harness.[/font]
[font=verdana]The original motherboard and connector are removed from the ECU case, and the Autronic motherboard and connector, clips or screws into the case. The original harness plugs in and the job is done, no wiring and all original sensors are used. External view of ECU case and connector is unchanged from its stock appearance.[/font]
[font=verdana]Considerable gains in power across the complete RPM range can be achieved with these boards. Both road car and Group N rally car versions available.[/font]
[font=verdana]Allows full control over fuel, ignition timing, boost pressure and all other engine functions. All boards have Anti-lag and Autotune.[/font]
[font=verdana]All boards are supplied with base programs are available. Some final tuning will be required.[/font]
[font=verdana]All these ECU except for the Subaru 2001-05 model are based on the SMC family of ECU with stepper idle control, ignition coil dwell and internal reluctor added.[/font][font=verdana]The Subaru 2001-2005 is based on the SM4.[/font][/size]
[font=verdana]ссылки по теме: http://www.tuspeed.com/autronic-wrxsti-plugin-ecu-board-p-1872.html[/font]
Re: Autronic ECU 99-00 WRX/STi plugin ecu board
Autronic - австралийская компания, которая базируется в Мельбурне. В 1987 была сформирована компания.
Autronic теперь производит три управленческих модели двигателя, SMC, SM2 и SM4 плюс правления замены для автомобилей Subaru WRX и Mitsubishi EVO. Все предложение трехмерное отображение топлива и воспламенения и полно последовательный. Также два выхлопных газа анализаторы, модели A и B.
Все системы управления двигателем Autronic доступны с дополнительной Автомелодией ™ чип и программное обеспечение, которое позволяет руки, бесплатная настройка без входа требуется от пользователя кроме управления двигателем через его различный RPM, и загрузите сайты.
Компания только небольшая, но это не остановило ее продажи систем управления двигателем ко многим частям мира. Системы управления двигателем хорошо уважают за там надежность и сопротивление вмешательству от других компонентов двигателя.
Системы управления двигателем Autronic будут управлять инжекторами правильно и известны их способностью управлять большими инжекторами на маленьких полных двигателях при маленьких открытиях инжектора.
Системы управления двигателем Autronic используются во всем мире в двигателях гонки в Группе A и гоночных автомобилях N и раллийных автомобилях, гонках Бремени, лодках гонки Водных лыж, Моторных катерах и выиграли главные гонки по всему миру.
Autronic ввел лодки лыжной гонки, выигранные в последнем 2001 мировые лыжные названия в США, беря первое и второе место.
Autronic произвел доски ЭКЮ замены за оригинальное ЭКЮ на Mitsubishi EVO 4,5,6,7 и 8. Subaru WRX 1995-96, 1997-98, 1999-00 и 2001-2005. Honda Civc/Integra 1992-95 (OBD1) и также автомобили 1996-00 OBD2, когда используется с поставляемым ремнем безопасности адаптера.
Оригинальная материнская плата и соединитель удалены из случая ЭКЮ, и материнской платы Autronic и соединителя, скрепок или винтов в случай. Оригинальный ремень безопасности включает, и работа сделана, никакая проводка и все оригинальные датчики не используются. Внешнее представление о случае ЭКЮ и соединителе неизменно от его внешности запаса.
Значительная прибыль во власти через полный диапазон RPM может быть достигнута с этими правлениями. И дорожный автомобиль и доступные версии раллийного автомобиля Группы N.
Позволяет полный контроль над топливом, выбором времени воспламенения, давлением наддува и всеми другими функциями двигателя. У всех правлений есть Антизадержка и Автомелодия.
Все правления снабжены основными программами, доступны. Некоторая заключительная настройка будет требоваться.
Все они, ЭКЮ за исключением модели Subaru 2001-05 основано на семье SMC ЭКЮ со степпером контроль без работы, катушка зажигания, живут и внутренний добавленный reluctor. Subaru 2001-2005 основана на SM4.
Snake, 3 тыщи баксов! Плюс растаможка
В наших условиях очень жадно - можно ej207 со шьющимися мозгами свапнуть!
- Snake
- Август 2012 / 593
Mit писал(а):Snake, 3 тыщи баксов! Плюс растаможкаВ наших условиях очень жадно - можно ej207 со шьющимися мозгами свапнуть!
Такие вещи покупают для конкретных целей так как они позволяют производить более тонкую настройку нежели штатные ECU так что когда требуется очень точный инструмент цена не имеет значения
- Donorparts
- Январь 2010 / 501
Могу продать за пол цены )
- Snake
- Август 2012 / 593
Donorparts писал(а):Могу продать за пол цены )
Мне помнится ты ещё крышку обещал продать для редуктора и пропал куда то
- Donorparts
- Январь 2010 / 501
а мне помнитмя что было немного по другому ) мозгиесть в наличии )Snake писал(а):Мне помнится ты ещё крышку обещал продать для редуктора и пропал куда то
- Snake
- Август 2012 / 593
Donorparts писал(а):а мне помнитмя что было немного по другому ) мозгиесть в наличии )
именно для эти годов 99-00 WRX/STi да и в теме крышки отпишись плиз
исправил форматирование
- Donorparts
- Январь 2010 / 501
Snake, есть у меня для 00-04
есть у товарища для 98-00 т.е 205/207 мотор поколения GC8
